SVGALIB 1.4.1 -- port to RTEMS
Rosimildo daSilva
rosimildo at xoommail.com
Fri Mar 10 16:13:13 UTC 2000
"Greg Haerr" wrote:
> : In order to improve the availability of video drivers for RTEMS &
> : Microwindows
> : running on a PC ( PC386 ), I have ported the drawing back-end of the
> : SVGALIB. It is a partial port.
> : Now, MicroWindows demos looks a lot better with 256 colors. :-).
> Rosimildo -
> Extremely impressive!! So RTEMS now links with SVGALIB
> to get the video setup?
Yes.
> I presume you're still using the framebuffer api on the top end, so SVGALIB
> gives you the linear address for the video ram?
That has been my goal. Unfortunately, my Video Card does not support
linear address, ( it failed with the testlinear.exe program ),
and I end up using the scr_svga.c driver of MicroWindows.
Anyway, the goal is to use the framebuffer interface and use this
library to set the video cards in graphics mode. Hopefully, someone
out there has a video card with "linear" support to test this out.
Rosimildo.
______________________________________________________
Get your free web-based email at http://www.xoom.com
Birthday? Anniversary? Send FREE animated greeting
cards for any occasion at http://greetings.xoom.com
