In message <200003101417.OAA23089 at sheesh.cygnus.co.uk>you write: > > This looks like a problem with gcc under HP-UX, unrelated to gdb or > the PowerPC support. Absolutely correct, this is a GCC problem with the PA port. Someone should file a testcase to gcc-bugs. jeff
