CodeWarrior and RTEMS
Nigel Spon
nigel at adi.co.nz
Mon Mar 20 20:45:04 UTC 2000
> I'm using CodeWarrior for Embedded PowerPC, and a Wiggler for BDM
>> debugging. Should I
>> be able to integrate such porting of RTEMS?
Yup. I have done this for RTEMS 3.6 / CW EPPC 4.2 and it works very well
indeed. BDM debugging with an IDE is so good you won't want to use
anything else ever again...
Nigel Spon ADInstruments Ltd, Dunedin, NZ
"The command could not be completed because it cannot be moved into
itself"
