Re-creating BSP under RTEMS 4.5.0
Joel Sherrill
joel.sherrill at OARcorp.com
Thu Mar 23 14:00:49 UTC 2000
Patrick.VARNEY at syntegra.bt.co.uk wrote:
> I'm having trouble re-creating my BSP under RTEMS 4.5.0. I copied the BSP
> directory from 4.0.0 libbsp to 4.5.0 libbsp and likewise the <bsp>.cfg from
> ../make/custom. However, It's failing when trying to make preinstall for my
> BSP. Any clues ?
I am sure Ralf can provide many more details but the simple answer is
that
between 4.0 and now, RTEMS has moved to automake and greater compliance
with GNU conventions. In 4.0, there was a single configure script at
the
top of the tree. Now RTEMS is configured more like other GNU tools --
as
a collection of configurable entities. BSPs now have their own
configure
script.
I highly recommend you look at the Makefile.am's, configure.in, of a
similar
BSP. You might even want to consider running "bootstrap -c" from the
top
of the tree and looking at what is left. bootstrap generates/removes
all
automatically generated files. You will need automake and autoconf
installed
to do this.
> Patrick Varney
> Tel. 01932 773576
> Mob. 0771 8046 750
> email patrick.varney at syntegra.bt.co.uk
joel at OARcorp.com On-Line Applications Research
