Functions defined both in RTEMS and NEWLIB.
Charles-Antoine Gauthier
charles.gauthier at nrc.ca
Mon Mar 27 15:12:31 UTC 2000
Sergei Organov wrote:
> Hello,
> I'm configuring/building the RTEMS snapshot (20000118) for PowerPC/papyrus
> target as a first step of my attempt to port 4.x RTEMS to the MPC5xx
> processors. I use gcc-2.95.2 and newlib-1.8.2 (actually the latest version
> from CVS).
> The question is: where reentrant syscalls (_read_r, etc.) should reside? In
> RTEMS code or in NEWLIB? They were defined in both places and I removed them
> from NEWLIB by adding -DREENTRANT_SYSCALLS_PROVIDED to the 'newlib_cflags' in
> the RTEMS section of NEWLIB configuration file (newlib/configure.host). Is it
> the right thing to do? If so, then should I send a patch to Cygnus, or
> somebody from OAR will do it?
> Thanks,
> Sergei Organov.
Hum... If you use the powerpc-rtems target,
-DREENTRANT_SYSCALLS_PROVIDED is already thrown for you in
configure.host.
case "${host}" in
# RTEMS supplies its own versions of some routines:
# malloc() (reentrant version)
# exit() RTEMS has a "global" reent to flush
# signal()/raise() RTEMS has its own including pthread signals
# _XYZ_r() RTEMS has its own reentrant routines
# NOTE: When newlib malloc uses a semaphore, RTEMS will switch to that.
*-*-rtems*)
newlib_cflags="${newlib_cflags} -DHAVE_GETTIMEOFDAY -DMALLOC_PROVIDED
-DEXIT_PROVIDED -DMISSING_SYSCALL_NAMES -DSIGNAL_PROVIDED
-DREENTRANT_SYSCALLS_PROVIDED -DHAVE_OPENDIR"
I always do a one-tree build. I add a symlink to newlib-1.8.2/newlib in
egcs/ and then do a build in a separate tree. Add --with-newlib to the
list of arguments to ../egcs/configure.
Most RTEMS build bugs were ironed out in newlib-1.8.2. I should just
build.
Institute for Information Technology Institut de technologie de
l'information
National Research Council of Canada Conseil national de recherches du
Canada
