FW: procedure for building rtems-4.5.0beta2
Smith, Gene
Gene.Smith at sea.siemens.com
Mon May 1 15:18:59 UTC 2000
Matt sent me this procedure that he worked up for installing the beta for a
pc386. It works for me. Thought it might be useful to other new rtems users
out there. It also points out a few problems he found and how he fixed them.
-Gene
-----Original Message-----
Sent: Thursday, April 27, 2000 6:03 PM
To: Smith, Gene
Subject: procedure for building rtems-4.5.0beta2
I didn't even look at the old documentation on how to do it. The
procedure seems obvious after doing 4 or 5 times :).
Note: I "install" everything to a subdir of all the rest of the stuff.
That makes it easier to use multiple versions. This goes against the
official instructions, but I think it's better. These are instructions
for building a pc386 target.
hmm, this could be a shell script:
cd
mkdir rtems-4.5.0-beta2
cd rtems-4.5.0-beta2
mkdir archive install tools
cd archive
download from ftp.rtems.com/pub/rtems/betas/rtems-4.5.0-beta/c_tools and
put in archive
binutils-2.9.5.0.24.tar.gz
binutils-2.9.5.0.24-rtems-20000207.diff.gz
c_build_scripts-4.5.0-beta2.tgz
gcc-2.95.2.tar.gz
gcc-2.95.2-rtems-20000106.diff.gz
gdb-4.18.tar.gz
gdb-4.18-rtems-20000126.diff.gz
newlib-1.8.2.tar.gz
newlib-1.8.2-rtems-20000131.diff.gz
download from ftp.rtems.com/pub/rtems/betas/rtems-4.5.0-beta and put in
archive
hello_world_c.tgz
netdemos-4.5.0-beta2.tgz
rtems-4.5.0-beta2.tgz
cd ../tools
tar xzf ../archive/c_build_scripts-4.5.0-beta2.tgz
tar xzf ../archive/binutils-2.9.5.0.24.tar.gz
tar xzf ../archive/gcc-2.95.2.tar.gz
tar xzf ../archive/gdb-4.18.tar.gz
tar xzf ../archive/newlib-1.8.2.tar.gz
tar xzf ../archive/rtems-4.5.0-beta2.tar.gz
cd binutils-2.9.5.0.24
zcat ../../archive/binutils-2.9.5.0.24-rtems-20000207.diff.gz | patch
-p1
cd ../gcc-2.95.2
zcat ../../archive/gcc-2.95.2-rtems-20000106.diff.gz | patch -p1
cd ../gdb-4.18
zcat ../../archive/gdb-4.18-rtems-20000126.diff.gz | patch -p1
cd ../newlib-1.8.2
zcat ../../archive/newlib-1.8.2-rtems-20000131.diff.gz | patch -p1
( note that you don't have to search for .rej files because patch will
complain verbosly if a patch fails )
cd ~/rtems-4.5.0-beta2/tools
edit user.cfg so that it has these at the top:
BINUTILS=binutils-2.9.5.0.24
GCC=gcc-2.95.2
NEWLIB=newlib-1.8.2
GDB=gdb-4.18
BUILD_DOCS=yes
BUILD_OTHER_LANGUAGES=no
INSTALL_POINT=~/rtems-4.5.0-beta2/install
RTEMS=rtems-4.5.0-beta2
the rest are probably ok with the default, save the file.
************this is the main fix I had to do****************
export PATH=$PATH:~/rtems-4.5.0-beta2/install/bin
even though it doesn't exist yet
this next thing is optional, I just did it so that debugging info wasn't
in the toolchain.
edit line 157 of bit to:
CFLAGS="-O2 -m486" ../${BINUTILS}/configure --target=${target} \
edit line 180 of bit to:
CFLAGS="-O2 -m486" ../${GCC}/configure --target=${target} \
edit line 196 of bit to:
CFLAGS_ARG="-O2 -m486"
ok. now your ready to go:
./bit i386
./bit_gdb i386
./bit_rtems i386 pc386
You don't need the toolchain sources anymore:
rm -rf newlib-1.8.2
rm -rf gdb-4.18
rm -rf gcc-2.95.2
rm -rf binutils-2.9.5.0.24
now, try making the latest and greatest hello_world
tar xzf ../archive/hello_world_c.tgz
cd hello_world_c
export RTEMS_MAKEFILE_PATH=~/rtems-4.5.0-beta2/install/pc386
make
I'm guessing that the program will be in o-optimize
cd o-optimize
now even the optimized build target has a lot of junk in it, it's
probably 844kb. Strip it.
i386-rtems-strip test.exe
That should bring it down to ~100K
Now, how to boot it..... Someone was nice enough to make a bare grub
boot floppy just for this purpose. Download
ftp://ftp.rtems.com/pub/rtems/betas/rtems-4.5.0-beta/contrib/pc386_grub_imag
e/README
and
e/grub144.gz
and follow those directions. I haven't tried that one, but it should
work. I used my own. (There are a few typo in the instructions, like gunzip
before copying!)
now, try making the netdemo demo:
tar xzf ../archive/netdemos-4.5.0-beta2.tgz
cd netdemos-4.5.0-beta2
I'm going to assume that you want to use the 3c509 driver.
edit networkconfig.h
comment out #define RTEMS_USE_BOOTP
after #include <bsp.h> add this:
#undef RTEMS_BSP_NETWORK_DRIVER_NAME
#undef RTEMS_BSP_NETWORK_DRIVER_ATTACH
#define RTEMS_BSP_NETWORK_DRIVER_NAME "ep0" /* don't use ep1 -- it won't
work!!! */
#define RTEMS_BSP_NETWORK_DRIVER_ATTACH rtems_3c509_driver_attach
comment out #define RTEMS_SET_ETHERNET_ADDRESS
change the ip addr and netmask in netdriver_config
at the end of
static struct rtems_bsdnet_ifconfig netdriver_config
comment out the
0 /* Use default driver parameters */
and add
0, /* ignore broadcast */
0, /* default mtu=0 */
0, /* rbuf_count */
0, /* xbuf_count */
0x300, /* base port of the board */
10, /* irq number of board */
0, /* memory on the board */
the default base port and irq for the 3c509 are 0x300 and 10, if you
know what they are for the specific machine you want to run it on, put
them here. I think the 3c509 driver does some sort of isa bus probing,
so I think its safe to leave everything other than the base port as
zero.
change rtems_bsdnet_config to one you know that works
*********this was another fix I had to do*****************
cd netdemo
edit Makefile line 57 so that it looks like this:
${PGM}: $(OBJS) #$(LINK_FILES)
make
you should have something in o-optimize, if you want to fit it on a grub
floppy, you'll probably have to strip it.
That's it
Matt
