No .reset No .initial
Smith, Gene Gene.Smith at sea.siemens.com
Wed May 3 17:33:47 UTC 2000
I am resubmitting this query since it appeared that the mail list may have
been down and possibly dropped some messages. -Gene
> -----Original Message-----
> From:	Smith, Gene
> Sent:	Wednesday, May 03, 2000 12:52 PM
> To:	'rtems'
> Subject:	No .reset No .initial
> Using the 4.5.0-beta2, the build process for my custom made bsp, cp386sx,
> produces the hello_world_c output file test.coff. When I download it with
> gdb I see that only sections .data and .text are sent to the target board.
> When I run test.coff through objdump, it list the sections .reset and
> .initialize as being present but does not show the assemby code for these
> sections.  The code for these is in files
> libbsp/i386/cp386sx/start/start.S and the cp386sx bsp is based on the
> i386ex bsp.  This worked fine with 4.0.0 (.reset and .initialize
> downloaded to the target with gdb and assemby for these sections was
> present in the file produced by objdump).  I have tried other options on
> objdump such as -D but these sections do not appear as assembly in the
> dump file.
> -Gene
