rtems-4.5.0-beta/c_tools build error
Stephan Wilms Stephan.Wilms at CWA.de
Tue May 2 07:54:10 UTC 2000
Hi Eli Kozikaro,
> I'm using  RedHat 6.2 and  rtems-4.5.0-beta.
> I untared the  tools and applied the patches then I ran ./bit m68k
> The ./bit m68k build did not complete  (see error messages bellow).
> I was able to complete the build when I added the install point
> (/usr/local/rtems/bin ) to the PATH environment variable.
> I wonder if this is a bug or am I missing a step.
It apears to be a bug, or at least an omission in the "bit" script. As
far as I know OAR is looking into this (I reported this last week).
Your fix is correct: when you want to use the current "bit" script you
must add the <INSTALL_POINT>/bin subdirectory to the PATH.
OAR says they'll put a fix right into the "bit" script, so this won't
be needed with future releases.
Greetings,
Stephan Wilms (stephan.wilms at cwa.de)
CWA-GmbH, Aachen, Germany
