FW: procedure for building rtems-4.5.0beta2
James Housley jim at thehousleys.net
Fri May 5 13:13:34 UTC 2000
Joel Sherrill wrote:
> My favorite trick is to either run the configure script
> as "sh -x configure" and log the output or
> add a set -x above and set +x below the part I am concerned about.
Not only that but you probably will want to run "script" first to log to
a file the many screens of data that will go screaming by.
Jim
Unix is like a wigwam -- no Gates, no Windows, and an Apache inside.
