FW: procedure for building rtems-4.5.0beta2
Mike Davies mikert at noco.demon.co.uk
Tue May 9 19:15:37 UTC 2000
In message <391738B4.A1446F52 at OARcorp.com>, Joel Sherrill
<joel.sherrill at OARcorp.com> writes
>None of the bit scripts should be run inside the source tree
>for the corresponding tool.  So bit_rtems should not be run
>from inside the RTEMS source tree.
>What directory are you in when you run bit_rtems?  I think there is
>a directory structure problem.  The bit_rtems script and supporting
>files should be in the same directory as rtems-4.5.0-beta2.
My directory structure is as follows :
/home/mike/rtems-4.5.0-beta2/  contains the following subdirectories :
archive
install
tools
/home/mike/rtems-4.5.0-beta2/tools  contains the following files and
directories :
binutils-2.9.5.0.24
bit
bit_gdb
bit_rtems
build-i386-rtems
common.sh
gcc-2.95.2
gdb-4.18
newlib-1.8.2
rtems-4.5.0-beta2
user.cfg
the build-i386-rtems directory is generated by the "bit_rtems i386
pc386" command.
>In this case, the setting for RTEMS in user.cfg is rtems-4.5.0-beta2.
>> Should the bit_rtems script include the user_cfg script ?
>Yes.  It is where all the tailorable information is set.
OK,  I've re-examined the bit_rtems script and it does indeed include
the user.cfg file (this is where the name build-i386-rtems comes from of
course)
Thanks,
Mike Davies
