4.5.0 B2 configure fun
Nick.SIMON at syntegra.bt.co.uk
Thu May 11 12:51:25 UTC 2000
Thanks, Joel, that was on the right lines. This is on a new machine, and
I'd not installed the glibc-devel RPM.
Now, however, I'm getting:
onfiguring in powerpc-rtems/c
running /bin/sh ../../../rtems-4.5.0-beta2/c/configure
--target=powerpc-rtems --disable-posix --disable-itron --enable-cxx
--enable-rtemsbsp=eth-comm --cache-file=./config.cache
--srcdir=../../../rtems-4.5.0-beta2/c
loading cache ./config.cache
checking for RTEMS Version... 4.5.0-beta2
checking host system type... i586-pc-linux-gnu
checking target system type... powerpc-unknown-rtems
checking build system type... i586-pc-linux-gnu
checking rtems target cpu... powerpc
checking for a BSD compatible install... /usr/bin/install -c
checking whether build environment is sane... yes
checking whether make sets ${MAKE}... yes
checking for working aclocal... found
checking for working autoconf... found
checking for working automake... found
checking for working autoheader... found
checking for working makeinfo... found
checking whether to enable maintainer-specific portions of Makefiles... no
checking if cpu powerpc is supported... yes
checking for make/custom/eth-comm.cfg... configure: error: no
configure: error: ../../../rtems-4.5.0-beta2/c/configure failed for c
At this point there are no .cfg files in build/make/custom. Environment is
Red Hat 6.1. Any ideas?
-- Nick Simon
> -----Original Message-----
> From: Joel Sherrill [mailto:joel.sherrill at OARcorp.com]
> Sent: 11 May 2000 12:25
> To: Nick.SIMON at syntegra.bt.co.uk
> Cc: rtems-users at OARcorp.com
> Subject: Re: 4.5.0 B2 configure fun
> Nick.SIMON at syntegra.bt.co.uk wrote:
> > Dear chaps,
> > I'm doing:
> > ../rtems-4.5.0-beta2/configure --target=powerpc-rtems
> --disable-posix
> > --disable-itron --enable-cxx --enable-rtemsbsp="eth-comm"
> > and getting lots of other stuff followed by:
> > checking for Cygwin environment... no
> > checking for mingw32 environment... no
> > checking for executable suffix... configure: error: installation or
> > configuration problem: compiler cannot create executables.
> > configure: error:
> ../../../rtems-4.5.0-beta2/tools/build/configure failed
> > for tools/build
> > I've got powerpc-rtems-gcc and the binutils in the path,
> build path (where
> > I/m running the configure) is /home/rtems/build.
> > Any ideas?
> What host are you on again? Is the native compiler
> named "cc" or "gcc"?
> Try CC=gcc .../configure ....
> > -- Nick Simon
> Joel Sherrill, Ph.D. Director of Research & Development
> joel at OARcorp.com On-Line Applications Research
> Ask me about RTEMS: a free RTOS Huntsville AL 35805
> Support Available (256) 722-9985
