beta3 test results for efi332 bsp
John S. Gwynne jsg at jsgpc.mrcday.com
Fri May 12 17:56:33 UTC 2000
I've run the test programs included with 4.5.0-beta3 with the efi332
bsp, and am happy to say most ran fine. Most if not all of the problem
are a direct result of a limited amount RAM in this target (512k). In
short, unlimited.nxe, psxfile01.nxe, psxmount.nxe, and psxstat.nxe
appear too large, and rtems++.nxe and psxsem01.nxe _may be_ too
large. It would be helpful to small board without much memory to split
those tests into two or more smaller tests that would run on all
boards. The failure of sp28.nxe, rtems++.nxe, and pscsem01.nxe are not
as clear. More details follow....
Thanks,
john gwynne
jsg at donet.com
These tests failed without a clear indication of the problem:
sp28.nxe: fails ((int)taskvar == localvar) test near line 58 of init.c
 prints:
   Task:3 taskvar:300 localvar:300
   Task:2 taskvar:200 localvar:200
   Task:1 taskvar:100 localvar:100
 then suspends.
 Question: should rtems_task_variable_delete clear these? does this
           test really work?
rtems++.nxe: Bus Error....
 prints:
   *** RTEMS++ TEST ***
   INIT - Task.create() - RTEMS[19] invalid thread priority
   INIT - Task.create() - RTEMS[00] successful completion
   INIT - Task.create() - RTEMS[16] illegal on calling thread
   INIT - Task.restart() - RTEMS[14] thread is in wrong state
   INIT - Task.start(0xDEADDEAD) - RTEMS[00] successful completion
   INIT - Destroy it's self
   RTEMS: Spurious interrupt: Bus Error
   RTEMS:    Vector: 0x00000002 sp: 0x000d21f8
 cause: The cause at the moment is unknown, but could be the result
        insufficient memory and failed malloc/constructor. This test use to
        work; is it still working on other targets?
psxsem01.nxe: bus error
  prints:
    *** POSIX SEMAPHORE MANAGER TEST 1 ***
    Init: sem_init - SUCCESSFUL
    RTEMS:    Vector: 0x00000002 sp: 0x000bed88
        insufficient memory and failed malloc. Is this working on other
        targets?
These tests are believed to use too much RAM:
unlimited.nxe: HEAP error, not enough RAM
psxfile01.nxe: lack of memory?
  fails part way through with...
  assertion "memory" failed: file "../../../../../../rtems-4.5.0-beta3/c/src/lib/libc/memfile.c", line 340
psxmount.nxe: lack of memory?
  assertion "memory" failed: file "../../../../../../rtems-4.5.0-beta3/c/src/lib/0
psxstat.nxe: lack of ram?
  prints:
    <delete>
    Attempting to mount IMFS file system at /dir1/my_mount_point
    rmdir /dir1/my_mount_point should fail with EBUSY
    Unmount /dir1/my_mount_point
    assertion "status == 0" failed: file "../../../../../../../rtems-4.5.0-beta3/c/src/tests/psxtests/psxstat/test.c", line 669
