Coldfire BDM + gdb + RTEMS 4.0 ?
Jake Janovetz janovetz at tempest.ece.uiuc.edu
Sun May 14 15:48:58 UTC 2000
Out of curiosity...
Why aren't the BDM drivers integrated into GDB yet?  I've been
patching gdb for two years now.  The BDM drivers seem very stable,
so why haven't the GDB folks accepted them?
    Cheers,
    Jake
> > > I went to David Fiddes web site, and found gdb 4.18 patches to work with
> > > the Linux BDM driver.  However, RTEMS 4.0 seems to require 4.17,
> > > according to the RTEMS Getting Started manual.
> > > How should I proceed to get RTEMS 4.0 running on the 5307 board using
> > > gdb and the Linux BDM driver?  I reviewed the mailing list archives,
> > > and it wasn't clear whether 4.0 support this configuration.
> > First things first... switch to 4.5-beta3 in ftp.oarcorp.com
> > /pub/rtems/betas/....
> The RTEMS 4.5 betas run well on the Coldfire.
> > Although there are no Coldfire BSPs included, David Fiddes has done
> > extensive work with RTEMS on the Coldfire.  If the PE Micro is
> > supported directly by gdb 4.18, you might be able to use the
> > RPMs.  Otherwise, there are bdm patches in the contrib directory
> > and RTEMS patches for 4.18 under c_tools/source.
> If using the lastest tool set, I suspect you will need the lastest gdb
> snapshot (and an updated GDB BDM patch). I found earlier gdb releases
> crashed with m68k-elf files. I have had no problems with the lastest
> snapshots.
> > What is on that eval board?
> The Cadre III board has Ethernet (ne2k clone), DRAM, serial points,
> flash, connectors.
>  Chris Johns, mailto:cjohns at cybertec.com.au mailto:ccj at acm.org
   janovetz at uiuc.edu    | How can it be that mathematics, being after all a
 University of Illinois | product of human thought independent of experience,
                        | is so admirably adapted to the objects of reality?
        PP-ASEL         |                                  - Albert Einstein
Disclaimer: The policies of this University certainly do not reflect my
            own opinions, objectives, or agenda.
