timercmp
gerke.kok at ascom.nl
Mon May 15 10:14:16 UTC 2000
Hello,
I try to build the beta3 of RTEMS with BSP=gen68360 and get the failure:
-D_RTEMS_RPC_INTERNAL_ -O4 -fomit-frame-pointer -o o-optimize/clnt_udp.o
rtems-4.5.0-beta3/c/src/librpc/src/rpc/clnt_udp.c
../../../../../../../rtems-4.5.0-beta3/c/src/librpc/src/rpc/clnt_udp.c: In
function `clntudp_ca
ll':
../../../../../../../rtems-4.5.0-beta3/c/src/librpc/src/rpc/clnt_udp.c:254:
warning: implicit d
eclaration of function `timerclear'
../../../../../../../rtems-4.5.0-beta3/c/src/librpc/src/rpc/clnt_udp.c:285:
warning: implicit d
eclaration of function `timerisset'
../../../../../../../rtems-4.5.0-beta3/c/src/librpc/src/rpc/clnt_udp.c:304:
warning: implicit d
eclaration of function `select'
../../../../../../../rtems-4.5.0-beta3/c/src/librpc/src/rpc/clnt_udp.c:307:
warning: implicit d
eclaration of function `timeradd'
../../../../../../../rtems-4.5.0-beta3/c/src/librpc/src/rpc/clnt_udp.c:309:
warning: implicit d
eclaration of function `timercmp'
parse error before
../../../../../../../rtems-4.5.0-beta3/c/src/librpc/src/rpc/clnt_udp.c:318:
warning: implicit d
eclaration of function `timersub'
../../../../../../../rtems-4.5.0-beta3/c/src/librpc/src/rpc/clnt_udp.c:321:
parse error before
../../../../../../../rtems-4.5.0-beta3/c/src/librpc/src/rpc/clnt_udp.c:274:
warning: label `sen
d_again' defined but not used
make[6]: *** [o-optimize/clnt_udp.o] Error 1
It looks like the function:
timercmp
is not defined. WHat do I do to get this running?
wkr,
Gerke
