Problem building beta3
Tue May 16 13:27:50 UTC 2000
Again this is because the newlib patch changed.  If you are on Linux,
then grab new RPMs.  Otherwise, you likely want to rebuild tools.
A hack is to install pthread.h with C library headers and manually
replace the time.h with the new one.  That is what the newlib patch
did.
But importantly... pthread.h moved to newlib so we can start to enable
the multithreaded support in gcc support libraries.
Nick.SIMON at syntegra.bt.co.uk wrote:
> Hi all,
> Having got to beta3 by applying the patches to beta2, I'm getting:
> /opt/rtems/bin/powerpc-rtems-gcc --pipe -B../../../../../../dhe860boot/lib/
> -specs bsp_specs -qrtems -g -Wall -ansi -fasm   -DPPC_ABI=PPC_ABI_EABI
> -DPPC_ASM=PPC_ASM_ELF -DPPC_VECTOR_FILE_BASE=0x00000000 -mcpu=860     -c
> '-D__P(x)=x' -D_read=read -D_write=write -D_close=close
> -D_RTEMS_RPC_INTERNAL_ -O2 -fno-keep-inline-functions -o
> o-optimize/clnt_udp.o
> ../../../../../../../rtems-4.5.0-beta3/c/src/librpc/src/rpc/clnt_udp.c
> ../../../../../../../rtems-4.5.0-beta3/c/src/librpc/src/rpc/clnt_udp.c: In
> function `clntudp_call':
> ../../../../../../../rtems-4.5.0-beta3/c/src/librpc/src/rpc/clnt_udp.c:254:
> warning: implicit declaration of function `timerclear'
> ../../../../../../../rtems-4.5.0-beta3/c/src/librpc/src/rpc/clnt_udp.c:285:
> warning: implicit declaration of function `timerisset'
> ../../../../../../../rtems-4.5.0-beta3/c/src/librpc/src/rpc/clnt_udp.c:304:
> warning: implicit declaration of function `select'
> ../../../../../../../rtems-4.5.0-beta3/c/src/librpc/src/rpc/clnt_udp.c:307:
> warning: implicit declaration of function `timeradd'
> ../../../../../../../rtems-4.5.0-beta3/c/src/librpc/src/rpc/clnt_udp.c:309:
> warning: implicit declaration of function `timercmp'
> parse error before `<'
> ../../../../../../../rtems-4.5.0-beta3/c/src/librpc/src/rpc/clnt_udp.c:318:
> warning: implicit declaration of function `timersub'
> ../../../../../../../rtems-4.5.0-beta3/c/src/librpc/src/rpc/clnt_udp.c:321:
> ../../../../../../../rtems-4.5.0-beta3/c/src/librpc/src/rpc/clnt_udp.c:274:
> warning: label `send_again' defined but not used
> <End of output>
> Looks to me like some macros omitted, but AFAIK I've not done anything near
> to RPCs.  Any ideas?
> -- Nick Simon
