mips64orion+.text address
Tue May 16 13:29:59 UTC 2000
Kai.Hackenstrass at barco.com wrote:
> hello,
> by testing rtems for a new bsp i want to shift the .text segment to a higher
> address than used for the p4600 bsp.
> trying to set the .text variable in the linkcmds file does not lead to the
> expected behaviour.
> searching all other files for the old .text address has no result, the only
> file including this address is linkcmds.
> does anybody know how i can shift the start address ?
That is how you do it.  Did you make sure it got installed and you are
really
using the modified one?
> > Kai Hackenstrass
> > System Software Developer
> > DR.SEUFERT GMBH
> > Barco Control Room Division
> > Mailto: Kai.Hackenstrass at barco.com
> > http://www.seufert.com
