Problem building beta3
Gus Paolone gus.paolone at fujitsu.com.au
Tue May 16 22:45:24 UTC 2000
Hi All;
Could you confirm the version of the tools? Which RPM files should I
get? I too wish to build beta3 and before I start I might as well get
the right versions of the tools.
Thanks
Gus
Joel Sherrill wrote:
> Again this is because the newlib patch changed.  If you are on Linux,
> then grab new RPMs.  Otherwise, you likely want to rebuild tools.
> A hack is to install pthread.h with C library headers and manually
> replace the time.h with the new one.  That is what the newlib patch
> did.
> But importantly... pthread.h moved to newlib so we can start to enable
> the multithreaded support in gcc support libraries.
> Nick.SIMON at syntegra.bt.co.uk wrote:
> > Hi all,
> > Having got to beta3 by applying the patches to beta2, I'm getting:
> > /opt/rtems/bin/powerpc-rtems-gcc --pipe -B../../../../../../dhe860boot/lib/
> > -specs bsp_specs -qrtems -g -Wall -ansi -fasm   -DPPC_ABI=PPC_ABI_EABI
> > -DPPC_ASM=PPC_ASM_ELF -DPPC_VECTOR_FILE_BASE=0x00000000 -mcpu=860     -c
> > '-D__P(x)=x' -D_read=read -D_write=write -D_close=close
> > -D_RTEMS_RPC_INTERNAL_ -O2 -fno-keep-inline-functions -o
> > o-optimize/clnt_udp.o
> > ../../../../../../../rtems-4.5.0-beta3/c/src/librpc/src/rpc/clnt_udp.c
> > ../../../../../../../rtems-4.5.0-beta3/c/src/librpc/src/rpc/clnt_udp.c: In
> > function `clntudp_call':
> > ../../../../../../../rtems-4.5.0-beta3/c/src/librpc/src/rpc/clnt_udp.c:254:
> > warning: implicit declaration of function `timerclear'
> > ../../../../../../../rtems-4.5.0-beta3/c/src/librpc/src/rpc/clnt_udp.c:285:
> > warning: implicit declaration of function `timerisset'
> > ../../../../../../../rtems-4.5.0-beta3/c/src/librpc/src/rpc/clnt_udp.c:304:
> > warning: implicit declaration of function `select'
> > ../../../../../../../rtems-4.5.0-beta3/c/src/librpc/src/rpc/clnt_udp.c:307:
> > warning: implicit declaration of function `timeradd'
> > ../../../../../../../rtems-4.5.0-beta3/c/src/librpc/src/rpc/clnt_udp.c:309:
> > warning: implicit declaration of function `timercmp'
> > parse error before `<'
> > ../../../../../../../rtems-4.5.0-beta3/c/src/librpc/src/rpc/clnt_udp.c:318:
> > warning: implicit declaration of function `timersub'
> > ../../../../../../../rtems-4.5.0-beta3/c/src/librpc/src/rpc/clnt_udp.c:321:
> > ../../../../../../../rtems-4.5.0-beta3/c/src/librpc/src/rpc/clnt_udp.c:274:
> > warning: label `send_again' defined but not used
> > <End of output>
> > Looks to me like some macros omitted, but AFAIK I've not done anything near
> > to RPCs.  Any ideas?
> > -- Nick Simon
> Joel Sherrill, Ph.D.             Director of Research & Development
> joel at OARcorp.com                 On-Line Applications Research
>    Support Available             (256) 722-9985
