Problem building beta3
Wed May 17 12:06:24 UTC 2000
Nick.SIMON at syntegra.bt.co.uk wrote:
> Gus,
> I'm using
> powerpc-rtems-binutils-2_9_5_0_24-1_i386.rpm
> powerpc-rtems-gcc-gcc2_95_2newlib1_8_2-5_i386.rpm
> rtems-base-binutils-2_9_5_0_24-1_i386.rpm
> rtems-base-gcc-gcc2_95_2newlib1_8_2-5_i386.rpm
Those are the current versions.
binutils 2.9.5.0.24 is at revision 1
gcc 2.95.2 + newlib 1.8.2 is at revision 5
gdb 4.18 is at revision 3
Note: Linux RPMS are built first.  Others follow.
Revision 5 of the gcc/newlib RPMs have the source
to support enabling multithread safe libraries but
unfortunately the RPMs were built WITHOUT specifying
the --enable-threads option.  So there WILL be a
revision 6 shortly.
--joel
> -- Nick Simon
> > -----Original Message-----
> > From: Gus Paolone [mailto:gus.paolone at fujitsu.com.au]
> > Sent: 16 May 2000 23:45
> > To: joel.sherrill at OARcorp.com
> > Cc: Nick.SIMON at syntegra.bt.co.uk; rtems-users at oarcorp.com
> > Subject: Re: Problem building beta3
> > Hi All;
> > Could you confirm the version of the tools? Which RPM files should I
> > get? I too wish to build beta3 and before I start I might as well get
> > the right versions of the tools.
> > Thanks
> > Gus
> <snip>
