RTEMS web server linking error !
Nick.SIMON at syntegra.bt.co.uk Nick.SIMON at syntegra.bt.co.uk
Thu May 18 07:58:56 UTC 2000
This problem still occurs with the http demo for beta3 - was there ever a
consensus on whether --noinhibit-exec was the right approach to this?
-- Nick Simon
> -----Original Message-----
> From: Ralf Corsepius [mailto:corsepiu at faw.uni-ulm.de]
> Sent: 30 March 2000 16:19
> To: Emmanuel Raguet
> Cc: rtems-users at usa.oarcorp.com
> Subject: Re: RTEMS web server linking error !
> Emmanuel Raguet wrote:
> > Ralf Corsepius wrote:
> > > > /opt/rtems/powerpc-rtems/bin/ld.exe -r -o o-optimize/temp.o
> > > > o-optimize/init.o -b binary o-optimize/tarfile
> > > => You are trying to link a tarfile. This will never work.
> > Yes, it will work.
> > I had the same problem but I have added the
> > "--noinhibit-exec"
> > option in the ld command and now it works fine.
> Hmm, from ld.info:
> --noinhibit-exec'
>      Retain the executable output file whenever it is still usable.
>      Normally, the linker will not produce an output file if it
>      encounters errors during the link process; it exits without
>      writing an output file when it issues any error whatsoever.
> Does this give any sense?
> May be I am missing something, but I am inclined to read this as
> "suppress linking errors and ignore them".
> Ralf
> Ralf Corsepius
> Forschungsinstitut fuer Anwendungsorientierte
> Wissensverarbeitung (FAW)
> Helmholtzstr. 16, 89081 Ulm, Germany     Tel: +49/731/501-8690
> mailto:corsepiu at faw.uni-ulm.de           FAX: +49/731/501-999
> http://www.faw.uni-ulm.de
