netdemos-4.5.0-beta3 build fails under rtems-4.5-beta3 for m6 8k (gen68360)
gerke.kok at ascom.nl gerke.kok at ascom.nl
Fri May 19 06:32:04 UTC 2000
Yep, just make a ln -s from librtemsall.a (or .so) to librtemsall. It's a
temp-fix but it works realy fine!
wkr,
Gerke
> -----Original Message-----
> From: OUTWATER [mailto:vac4050 at cae597.rsc.raytheon.com]
> Sent: Friday, May 19, 2000 01:30
> To: rtems-users at oarcorp.com
> Subject: netdemos-4.5.0-beta3 build fails under
> rtems-4.5-beta3 for m68k
> (gen68360)
> All -
> Had this problem under rtems-4.5-beta2 also.
> I've sucessfully built all of the beta3 c_tools as well as
> the beta3 of RTEMS on a stock
> Redhat 6.2 x86 system.
> Invoking make in the netdemo directory produces:
> darkstar:/home/vac4050/projects/netdemos-4.5.0-beta3/netdemo> make
> test -d o-optimize || mkdir o-optimize
> /home/vac4050/usr/local/rtems/bin/m68k-rtems-gcc --pipe
> -B/home/vac4050/usr/local/rtems//gen68360/lib/ -specs
> bsp_specs -qrtems -g -Wall -ansi -fasm
>  -O4 -fomit-frame-pointer       -mcpu32      -c   -o
> o-optimize/init.o init.c
> o-optimize/test.o test.c
> make: *** No rule to make target
> `/home/vac4050/usr/local/rtems//gen68360/lib/librtemsall',
> needed by `o-optimize/netdemo.exe'.  Stop.
> I followed up "m ds <mdsdm at yahoo.com>"'s suggestion, but the
> fix described in the archive
> appears to have already been applied to RTEMS beta3.
> Does anyone else using the gen68360 BSP have this problem?
> Thanks,
> Keith
