changeing the IP address
Erwin Rol 320094152587-0001 at t-online.de
Mon May 22 16:04:18 UTC 2000
Is it possible to change the IP address (, netmask and gateway)
from a running system without reboot (re-init) ?
I only found a reference on setting up the address at init time
but don't realy understand if the same thing should be used
for reconfiguration at runtime.
TIA,
Erwin
        Q - S O F T - E N G I N E E R I N G
     Rodachtalweg 11, 81549 Muenchen, Germany
Erwin Rol (Software Engineer)     phone: +49-89-68050051
Erwin.Rol at Q-Soft-Engineering.com  fax  : +49-89-68050052
