gethostbyname in GoAhead
Chris Johns cjohns at cybertec.com.au
Wed May 24 12:53:35 UTC 2000
Nick.SIMON at syntegra.bt.co.uk wrote:
> My web server startup is failing because it uses gethostname and
> gethostbyname to find the card's own IP address.  I don't really want to
> have my card registered with any off-card directory servers at the moment,
> is there any way of feeding the card's host entry into the stack so that
> gethostbyname works, or will I have to change GoAhead?
Create a file called `/etc/host.conf' and put in it :
  hosts,bind
Then create a file `/etc/hosts' and put in it :
  127.0.0.1  localhost.localdomain  localhost
To create file files you need to call `mkdir' then `open' etc.
I have some C code which creates these files which I can send you if you
wish.
 Chris Johns, mailto:cjohns at cybertec.com.au mailto:ccj at acm.org
