gethostbyname in GoAhead
Nick.SIMON at syntegra.bt.co.uk Nick.SIMON at syntegra.bt.co.uk
Wed May 24 14:21:48 UTC 2000
Hmm, I can't create a file with a '/' in its pathname.  Should I be able to?
-- Nick Simon
> -----Original Message-----
> From: Chris Johns [mailto:cjohns at cybertec.com.au]
> Sent: 24 May 2000 13:54
> To: Nick.SIMON at syntegra.bt.co.uk
> Cc: rtems-users at oarcorp.com
> Subject: Re: gethostbyname in GoAhead
> Nick.SIMON at syntegra.bt.co.uk wrote:
> > My web server startup is failing because it uses gethostname and
> > gethostbyname to find the card's own IP address.  I don't
> really want to
> > have my card registered with any off-card directory servers
> at the moment,
> > is there any way of feeding the card's host entry into the
> stack so that
> > gethostbyname works, or will I have to change GoAhead?
> Create a file called `/etc/host.conf' and put in it :
>   hosts,bind
> Then create a file `/etc/hosts' and put in it :
>   127.0.0.1  localhost.localdomain  localhost
> To create file files you need to call `mkdir' then `open' etc.
> I have some C code which creates these files which I can send
> you if you
> wish.
>  Chris Johns, mailto:cjohns at cybertec.com.au mailto:ccj at acm.org
