Friendly warning on downloading RPMs :)
Joel Sherrill
joel.sherrill at OARcorp.com
Thu May 25 18:00:58 UTC 2000
Hi,
We have been watching the ftp logs this morning and we noticed
that more than one person has to be retrieving WAY more than
they need. We don't have infinite bandwidth and there is
WAY more on the ftp site than any one project could possibly
need or really want. :)
A lot of thought went into the organization of the RPMs to
avoid downloading things you would not need. Just to make
sure it gets said once, here is a list of RPMs and what you
are likely NOT to need:
WILL NEED:
rtems-base-binutils-2.9.5.0.24-1.i386.rpm
rtems-base-gcc-gcc2.95.2newlib1.8.2-6.i386.rpm
CPU-rtems-binutils-2.9.5.0.24-1.i386.rpm
CPU-rtems-gcc-gcc2.95.2newlib1.8.2-6.i386.rpm
LIKELY TO NEED (some configurations use special gdbs like BDM)
rtems-base-gdb-4.18-3.i386.rpm
CPU-rtems-gdb-4.18-3.i386.rpm
UNLIKELY TO NEED:
CHILL:
rtems-base-chill-gcc2.95.2newlib1.8.2-6.i386.rpm
CPU-rtems-chill-gcc2.95.2newlib1.8.2-6.i386.rpm
Fortran:
rtems-base-g77-gcc2.95.2newlib1.8.2-6.i386.rpm
CPU-rtems-g77-gcc2.95.2newlib1.8.2-6.i386.rpm
GJC (Java Compiler) (experimental at best :):
rtems-base-gcj-gcc2.95.2newlib1.8.2-6.i386.rpm
CPU-rtems-gcj-gcc2.95.2newlib1.8.2-6.i386.rpm
Objective-C:
CPU-rtems-objc-gcc2.95.2newlib1.8.2-6.i386.rpm
I did some quick checks and JUST on the sparc:
Required: 8,452,948 bytes
Likely: 2,552,851 bytes
Not Likely: 7,943,419 bytes
That means that over 1/2 of what you download is not
needed to build RTEMS or most applications.
On top of that, we are seeing people retrieve the entire
set of RPMS for all targets. I doubt anyone needs
every language for every target. This means you
would have downloaded 175 MBYTES instead of 10-17Mbytes.
That is only for Linux. There are also Cygwin RPMs
and will (hopefully) soon be Solaris ones as well.
They will be in multiple formats (RPM and .tgz for all)
and .deb for Linux. That means that by pointing your
ftp client and clicking get all, you could easily
retrieve over 1 GBYTE of stuff you don't need.
Just a friendly warning. :)
joel at OARcorp.com On-Line Applications Research
