CygWin - RPMS --- problems
Rosimildo da Silva rdasilva at connecttel.com
Fri May 26 13:09:37 UTC 2000
I have got the a compilation problem, after getting the
RPMS installed last night. The bsp_specs fie is there on its
usual place. I have ran "dos2unix" on it just in case,
but it did not help.
NOTE: I am using CygWin 1.1, and this could be the reason that
I am facing a few problems.
Rosimildo.
make[8]: Nothing to be done for `all-am'.
make[8]: Leaving directory
`/tools/build-i386-rtems/i386-rtems/c/pc386/exec/scor
e/cpu/i386/rtems'
make[7]: Leaving directory
e/cpu/i386/rtems'
make[7]: Entering directory
re/cpu/i386'
/opt/rtems/bin/i386-rtems-gcc --pipe -B../../../../../../.././pc386/lib/
-specs
bsp_specs -qrtems -g -Wall -ansi -fasm         -c  -O4 -o
o-optimize/cpu.o ../..
/../../../../../../rtems-4.5.0-beta3/c/src/exec/score/cpu/i386/cpu.c
i386-rtems-gcc: bsp_specs: No such file or directory
make[7]: *** [o-optimize/cpu.o] Error 1
