CygWin - RPMS --- problems --- follow up -- Success
Rosimildo da Silva rdasilva at connecttel.com
Fri May 26 15:31:43 UTC 2000
 !!! ARGHHHHHHHHHHHHHHHHHHHHHHHHHHHHHHHHHHHHHHHHHHH !!!!!!!!!
It is the f@#$ing CygWin 1.1 that is causing problems.
It installs the "/" mount point as binmode. I created
a directory underneath it for RTEMS development, and it
behaves in "binmode" as well. This makes some tools to
behave very strange.
I had to mount a new mount point for RTEMS development
in "textmode". Reconfigured it again, and now everything compiles fine.
Finally, I have got beta3 working and using the RPMS for Cygwin.
NOTE: After I apply some patches to the code, and had to
"bootstrap" it again, I've got this error. It does not
seem to affect what I am doing, but it would be nice to
have it corrected.
bash-2.03$ ./bootstrap
./c
./c/make
./c/src
./c/src/exec
./c/src/exec/itron
./c/src/exec/posix
./c/src/exec/score/cpu/a29k
./c/src/exec/score/cpu/hppa1.1
./c/src/exec/score/cpu/i386
./c/src/exec/score/cpu/i960
./c/src/exec/score/cpu/m68k
./c/src/exec/score/cpu/mips64orion
./c/src/exec/score/cpu/no_cpu
./c/src/exec/score/cpu/powerpc
./c/src/exec/score/cpu/sh
./c/src/exec/score/cpu/sparc
./c/src/exec/score/cpu/unix
./c/src/lib
makefile.am:8: variable `LIBHWAPI' not defined
./c/src/lib/libbsp/a29k
./c/src/lib/libbsp/a29k/portsw
Rosimildo.
Rosimildo da Silva wrote:
> I have got the a compilation problem, after getting the
> RPMS installed last night. The bsp_specs fie is there on its
> usual place. I have ran "dos2unix" on it just in case,
> but it did not help.
> NOTE: I am using CygWin 1.1, and this could be the reason that
> I am facing a few problems.
> Rosimildo.
> make[8]: Nothing to be done for `all-am'.
> make[8]: Leaving directory
> `/tools/build-i386-rtems/i386-rtems/c/pc386/exec/scor
> e/cpu/i386/rtems'
> make[7]: Leaving directory
> e/cpu/i386/rtems'
> make[7]: Entering directory
> re/cpu/i386'
> /opt/rtems/bin/i386-rtems-gcc --pipe -B../../../../../../.././pc386/lib/
> -specs
> bsp_specs -qrtems -g -Wall -ansi -fasm         -c  -O4 -o
> o-optimize/cpu.o ../..
> /../../../../../../rtems-4.5.0-beta3/c/src/exec/score/cpu/i386/cpu.c
> i386-rtems-gcc: bsp_specs: No such file or directory
> make[7]: *** [o-optimize/cpu.o] Error 1
Rosimildo da Silva            rdasilva at connectel.com
ConnectTel, Inc.              Austin, TX -- USA
Phone : 512-338-1111          Fax : 512-918-0449
Mobile: 512-632-7579
Company Page: http://www.connecttel.com
Home Page: http://members.xoom.com/rosimildo/
