Filesystem & SoundBlaster
Rosimildo da Silva rdasilva at connecttel.com
Wed May 31 18:13:24 UTC 2000
From: Alejandro Villanueva <alex at robot18.cps.unizar.es>
To: <rtems-users at OARcorp.com>
Sent: Wednesday, May 31, 2000 12:29 PM
Subject: Filesystem & SoundBlaster
> Hi there!
> just a begginer's question... does RTEMS support any filesystem? I'm
actually
> dessigning an embedded system using the PC386 BSP and need desperately
> to read/write files. I'm using RTEMS 4.0.0 with the GNAT/RTEMS Ada95
compiler.
RTEMS does not have a "persistent" file system yet.  RTEMS 4.5.0 has a
In-Memory-File-System( IMFS ). All it is required is somebody to write a
driver to read/write to disk.
> Another easy question... what about a SoundBlaster device driver? ;-)
I do not think there is one.
This would be a good add-on to MicroWindows. :-).
Rosimildo.
