PThread
Wed May 3 16:45:10 UTC 2000
"Gu, Yi (Yi)** CTR **" wrote:
> Is PThread compatible with RTEMS native task?
I do not understand the question.
RTEMS has support for 3 APIs:
  - Classic RTEID API             (on by default)
  - POSIX API (includes pthreads) (--enable-posix)
  - uITRON API                    (--enable-itron)
The POSIX API has threads that are POSIX 1003.1b
compliant.  That makes them compatible with POSIX
threads packages on numerous UNIX flavors.
Threads/tasks created with any of the APIs can use
services from the other APIs.  For example, Classic
API tasks can block on a POSIX mutex.
> Yi
