FW: procedure for building rtems-4.5.0beta2
Andrew Bythell
abythell at nortelnetworks.com
Thu May 4 13:14:51 UTC 2000
Mike Davies wrote:
> checking for Cygwin environment... no
> checking for mingw32 environment... no
> checking for executable suffix... configure: error: installation or
> configuratio
> n problem: compiler cannot create executables.
> configure: error: ../../../rtems-4.5.0-beta2/tools/build/configure
> failed for to
> ols/build
> Could not successfully configure into build-i386-rtems!
I ran into this problem while building on a Solaris host. I had a look
in:
../../../rtems-4.5.0-beta2/tools/build/configure/config.status (or was
it config.log?)
and it gave me more details about the problem. ( Turned out that it was
using 'cc', not 'gcc', so I just set $CC=gcc, though that probably isn't
your problem. )
Andrew Bythell System Verification
Nortel Networks Microelectronics Group
Ottawa, Ontario Canada esn.39.56930
tel.613.765-6930 fax.613.763-7795
