FW: procedure for building rtems-4.5.0beta2
Joel Sherrill
joel.sherrill at OARcorp.com
Fri May 5 01:52:09 UTC 2000
Mike Davies wrote:
> >Try this:
> >"./bit_rtems i386-elf pc386"
> >If this solves the problem, we might have a hidden bug in the
> >bit script.
> No, that didn't make any difference.
> Is there any way of making the rtems configure script give a more
> verbose account of what it is doing ? This would be easier to debug
> than typing it out line by line 'till I find what the problem line is !
My favorite trick is to either run the configure script
as "sh -x configure" and log the output or
add a set -x above and set +x below the part I am concerned about.
> Thanks,
> Mike Davies
joel at OARcorp.com On-Line Applications Research
