Timmer & timer-ticks on 68360
Joel Sherrill
joel.sherrill at OARcorp.com
Thu May 11 16:51:58 UTC 2000
Jake Janovetz wrote:
> I've had this trouble before. It has to do with the way your
> clock/PLL is configured for your board versus how Eric set things
> up for the BSP. I _believe_ Eric assumes a 25 MHz clock oscillator
> connected to the 68360 whereas things will be slightly different if
> you use a 4 MHz oscillator and work with that (which is what I do).
> If you think this could be the source of your trouble, let me know
> and I can email you changes I make to the BSP.
Jake/Eric, is clock speed something that could come from the linkcmds
file?
I think the sparc/erc32 BSP did it this way.
> Cheers,
> Jake
> On Thu, May 11, 2000 at 06:26:38PM +0200, gerke.kok at ascom.nl wrote:
> > Hello,
> > we are porting the gen68360 BSP to our board. With succes, even TCP/IP works
> > nice. But now get stuck on the timmer stuff. What do we do wrong or have we
> > forgotten when 5 sec. in the ticker example actualy gets to be 30 sec? We
> > have a straigt 4.5.0 beta 2 release installed.
> > Thanks for any help.
> > wkr,
> > Gerke
> janovetz at uiuc.edu | How can it be that mathematics, being after all a
> University of Illinois | product of human thought independent of experience,
> | is so admirably adapted to the objects of reality?
> PP-ASEL | - Albert Einstein
> Disclaimer: The policies of this University certainly do not reflect my
> own opinions, objectives, or agenda.
joel at OARcorp.com On-Line Applications Research
