Installin rpms on non-redhat system
jgais at ws.estec.esa.nl
Tue May 16 08:32:30 UTC 2000
Ralf Corsepius wrote:
> jgais at ws.estec.esa.nl wrote:
> > Is there a way of installing the binary rpms on a non-redhat system?
> > I'm using slackware-7.0, and the rpm2tgz utilities only return an
> > empty tar file when I run it on the rtems rpms.
> I don't know what rpm2tgz is, however I have been able to
> successfully convert the rpms to slp and tgz using alien under SuSE
> (an rpm based distribution).
Thanks for the tip - however, all I needed was to use the -nodeps
switch in rpm to bypass dependency checking (thanks Oscar).
Jiri.
Jiri Gaisler, ESA/ESTEC, Box 299, 2200 AG Noordwijk, the Netherlands
email: jgais at ws.estec.esa.nl voice:+31-71-5654880 fax:+31-71-5654295
ERC32 home page at http://www.estec.esa.nl/wsmwww/erc32
