mips64orion+.text address
Kai.Hackenstrass at barco.com
Tue May 16 14:42:04 UTC 2000
hello,
i am sure i have used the changed linkcmds file, because there is only this
file named linkcmds. even after recompiling of the whole rtems package (for
information : 4.5.0 beta 2) the result is the same. i do not find the old
start address in all other files placed in the rtems directories. the
default address is 0x80030000 and this pattern is never declared.
? : what must i do after changing the start address in linkcmds :
- recompile rtems packge ?
- recompile samples ?
- other activities ?
kai
-----Original Message-----
From: Joel Sherrill [mailto:joel.sherrill at OARcorp.com]
Sent: Tuesday, May 16, 2000 15:30
To: Kai.Hackenstrass at barco.com
Cc: rtems-users at OARcorp.com
Subject: Re: mips64orion+.text address
Kai.Hackenstrass at barco.com wrote:
> hello,
> by testing rtems for a new bsp i want to shift the .text segment to a
higher
> address than used for the p4600 bsp.
> trying to set the .text variable in the linkcmds file does not lead to the
> expected behaviour.
> searching all other files for the old .text address has no result, the
only
> file including this address is linkcmds.
> does anybody know how i can shift the start address ?
That is how you do it. Did you make sure it got installed and you are
really
using the modified one?
> > Kai Hackenstrass
> > System Software Developer
> > DR.SEUFERT GMBH
> > Barco Control Room Division
> > Mailto: Kai.Hackenstrass at barco.com
> > http://www.seufert.com
joel at OARcorp.com On-Line Applications Research
