mips64orion+.text address
Kai.Hackenstrass at barco.com
Tue May 16 15:43:02 UTC 2000
thanks a lot, that's it !
kai
-----Original Message-----
From: Joel Sherrill [mailto:joel.sherrill at oarcorp.com]
Sent: Tuesday, May 16, 2000 17:09
To: Kai.Hackenstrass at barco.com
Cc: rtems-users at oarcorp.com
Subject: Re: mips64orion+.text address
Kai.Hackenstrass at barco.com wrote:
> hello,
> i am sure i have used the changed linkcmds file, because there is only
this
> file named linkcmds. even after recompiling of the whole rtems package
(for
> information : 4.5.0 beta 2) the result is the same. i do not find the old
> start address in all other files placed in the rtems directories. the
> default address is 0x80030000 and this pattern is never declared.
> ? : what must i do after changing the start address in linkcmds :
> - recompile rtems packge ?
> - recompile samples ?
> - other activities ?
I have seen this myself since the make-exe process is NOT dependent on
linkcmds!! rm all .exe files for the tests so they will regenerate.
> kai
> From: Joel Sherrill [mailto:joel.sherrill at OARcorp.com]
> Sent: Tuesday, May 16, 2000 15:30
> Cc: rtems-users at OARcorp.com
> > hello,
> > by testing rtems for a new bsp i want to shift the .text segment to a
> higher
> > address than used for the p4600 bsp.
> > trying to set the .text variable in the linkcmds file does not lead to
the
> > expected behaviour.
> > searching all other files for the old .text address has no result, the
> only
> > file including this address is linkcmds.
> > does anybody know how i can shift the start address ?
> That is how you do it. Did you make sure it got installed and you are
> really
> using the modified one?
> > > Kai Hackenstrass
> > > System Software Developer
> > > DR.SEUFERT GMBH
> > > Barco Control Room Division
> > > Mailto: Kai.Hackenstrass at barco.com
> > > http://www.seufert.com
> Joel Sherrill, Ph.D. Director of Research & Development
> joel at OARcorp.com On-Line Applications Research
> Ask me about RTEMS: a free RTOS Huntsville AL 35805
> Support Available (256) 722-9985
