Problem building beta3
Nick.SIMON at syntegra.bt.co.uk
Wed May 17 06:48:42 UTC 2000
Gus,
I'm using
powerpc-rtems-binutils-2_9_5_0_24-1_i386.rpm
powerpc-rtems-gcc-gcc2_95_2newlib1_8_2-5_i386.rpm
rtems-base-binutils-2_9_5_0_24-1_i386.rpm
rtems-base-gcc-gcc2_95_2newlib1_8_2-5_i386.rpm
-- Nick Simon
> -----Original Message-----
> From: Gus Paolone [mailto:gus.paolone at fujitsu.com.au]
> Sent: 16 May 2000 23:45
> To: joel.sherrill at OARcorp.com
> Cc: Nick.SIMON at syntegra.bt.co.uk; rtems-users at oarcorp.com
> Subject: Re: Problem building beta3
> Hi All;
> Could you confirm the version of the tools? Which RPM files should I
> get? I too wish to build beta3 and before I start I might as well get
> the right versions of the tools.
> Thanks
> Gus
<snip>
