RTEMS web server linking error !
Nick.SIMON at syntegra.bt.co.uk
Wed May 24 11:57:12 UTC 2000
Funny, that - I've been doing much the same. This tar approach is just
because I'm trying to go to GoAhead.
I share your concern about having the data in rom and in ram (in imfs).
Presumably to have "read only" rom files would mean changes to imfs. I may
address this if it turns out to be a problem.
My issue with the makefile is not so much the use of tar as the fact that
init.o gets doctored (breaks things if you make without make clean) and
there's no dependency on the http file(s). If I can get my immediate
problems sorted out I may produce another makefile.
TTFN
-- Nick Simon
> -----Original Message-----
> From: Rosimildo da Silva [mailto:rdasilva at connecttel.com]
> Sent: 24 May 2000 12:57
> To: Nick.SIMON at syntegra.bt.co.uk
> Cc: rtems-users at oarcorp.com
> Subject: Re: RTEMS web server linking error !
> Nick.SIMON at syntegra.bt.co.uk wrote:
> > Aha! My tarfile.o had _binary_o-optimize-tarfile_start
> etc. in it. Now
> > fixed. Here's a diff on netdemos-4.5.0-beta2/http/Makefile:
> > 59c59,61
> > < $(LD) -r -o $(ARCH)/temp.o $(ARCH)/init.o -b
> binary $(ARCH)/tarfile
> > > cp $(ARCH)/tarfile .
> > > $(OBJCOPY) -I binary -O elf32-powerpc tarfile
> $(ARCH)/tarfile.o
> > > $(LD) -r -o $(ARCH)/temp.o $(ARCH)/init.o $(ARCH)/tarfile.o
> > I'm not wild about this (esp having elf32-powerpc embedded
> in it), but it
> > seems to work.
> > Thanks for your help,
> > -- Nick Simon
> Nick,
> I did not like this either. For the pc386 I have written a
> small utility
> that
> generates a "C" file as a global array. This approach might
> have serious
> consequences on systems with low memory footprint, because
> you may endup
> with one
> copy of the array in ROM and another in RAM.
> For the PC386, this is not one issue and memory is not either. :-).
> It automatically creates the routine to call and initialize the FS in
> your main()
> routine.
> Rosimildo da Silva rdasilva at connectel.com
> ConnectTel, Inc. Austin, TX -- USA
> Phone : 512-338-1111 Fax : 512-918-0449
> Mobile: 512-632-7579
> Company Page: http://www.connecttel.com
> Home Page: http://members.xoom.com/rosimildo/
