gethostbyname in GoAhead
Chris Johns cjohns at cybertec.com.au
Wed May 24 13:12:51 UTC 2000
Nick.SIMON at syntegra.bt.co.uk wrote:
> Thanks, Chris.  I suppose this means GoAhead will see itself as 127.0.0.1 -
> does this matter?  Or should I put my 'proper' name and IP address in?
I would put in lines for all interfaces you have configured (I should
have read the rest of the source code I have and spotted this, sorry
about that).
> (This IMFS makes a big difference to RTEMS - I can see my mindset will have
> to change!)
I agree. I found the same problem you have and decided this was the best
fix as I did not change any code from the distribution. These files are
reference by the BSD stack.
 Chris Johns, mailto:cjohns at cybertec.com.au mailto:ccj at acm.org
