gethostbyname in GoAhead
Joel Sherrill
joel.sherrill at OARcorp.com
Wed May 24 15:18:30 UTC 2000
Nick.SIMON at syntegra.bt.co.uk wrote:
> DOH! I didn't mkdir....
I think you both have said it but I want to drive the point
home. :)
The RTEMS POSIX API, filesystem infrastructure, and support
for other standards like the BSD network stack are all
critical parts of making it easier to port softare to
RTEMS. The documentation set includes a POSIX 1003.1
Compliance Guide. RTEMS has about 85% of POSIX 1003.1b. :)
Eric N and Rosimildo have both ported multiple substantial
third party open source packages to RTEMS. The list
of portability issues grows shorter each time whether
you are moving code from Linux, *BSD, or a proprietary
RTOS.
--joel
> -- Nick Simon
> > -----Original Message-----
> > From: Nick.SIMON at syntegra.bt.co.uk
> > [mailto:Nick.SIMON at syntegra.bt.co.uk]
> > Sent: 24 May 2000 15:22
> > To: cjohns at cybertec.com.au
> > Cc: rtems-users at oarcorp.com
> > Subject: RE: gethostbyname in GoAhead
> > Hmm, I can't create a file with a '/' in its pathname.
> > Should I be able to?
> > -- Nick Simon
> > > From: Chris Johns [mailto:cjohns at cybertec.com.au]
> > > Sent: 24 May 2000 13:54
> > > To: Nick.SIMON at syntegra.bt.co.uk
> > > Subject: Re: gethostbyname in GoAhead
> > > > My web server startup is failing because it uses gethostname and
> > > > gethostbyname to find the card's own IP address. I don't
> > > really want to
> > > > have my card registered with any off-card directory servers
> > > at the moment,
> > > > is there any way of feeding the card's host entry into the
> > > stack so that
> > > > gethostbyname works, or will I have to change GoAhead?
> > > Create a file called `/etc/host.conf' and put in it :
> > > hosts,bind
> > > Then create a file `/etc/hosts' and put in it :
> > > 127.0.0.1 localhost.localdomain localhost
> > > To create file files you need to call `mkdir' then `open' etc.
> > > I have some C code which creates these files which I can send
> > > you if you
> > > wish.
> > > Chris Johns, mailto:cjohns at cybertec.com.au mailto:ccj at acm.org
joel at OARcorp.com On-Line Applications Research
