top level build problem c instead of "TARGET/c"
Joel Sherrill
joel.sherrill at OARcorp.com
Wed May 31 20:32:29 UTC 2000
"Aaron J. Grier" wrote:
> On Thu, May 25, 2000 at 02:25:32PM -0500, Joel Sherrill wrote:
> > Comments?
> It seems like you are already assuming GNU make to build RTEMS, so you
> minus well use internal GNU make functions and ditch sed entirely, if
> possible.
This particular sed is in the configure script so that is not possible.
And even worse... configure uses sed to generate Makefile's from
Makefile.in's. I don't see any easy way to generate a valid
Makefile in the libnetworking/include directory on Solaris using
/bin/sed. The set of preinstall filenames is too long for
/bin/sed to process.
> Aaron J. Grier | Frye Electronics, Tigard, OR | aaron at frye.com
> "The simplistic anthropomorphism which asserts that source code has a
> life separate from its creator or maintainer is the product of one
> too many viewings of Tron." -- paraphrasing of anonymous post on /.
joel at OARcorp.com On-Line Applications Research
