from a very newbie (I'm sorry)
Nick.SIMON at syntegra.bt.co.uk Nick.SIMON at syntegra.bt.co.uk
Thu Nov 9 11:38:21 UTC 2000
Is /opt/rtems/bin in your PATH?
-----Original Message-----
From: Pieter De Troyer [mailto:pieter.detroyer at mech.kuleuven.ac.be]
Sent: 09 November 2000 11:27
To: corsepiu at faw.uni-ulm.de
Cc: rtems-users at oarcorp.com
Subject: Re: from a very newbie (I'm sorry)
Hi,
thank you for your help, below i replied to your questions.
Thx
Pieter
> > checking for i386-gcc... no
> > checking for i386-cc... /opt/rtems/bin//i386-cc
> > checking whether the C compiler (/opt/rtems/bin//i386-cc  ) works... yes
> > checking whether the C compiler (/opt/rtems/bin//i386-cc  ) is a
> Where does this i386-cc come from?
I made a link to i386-cc a link to i386-rtems-gcc because if i don't do
that i get the next error while running configure (this time with the
right options, thank you for pointing me):
[pdtroyer at pc-10-33-39-170 build-rtems]$ ../rtems-4.5.0/configure
--target=i386-r
tems -enable-rtemsbsp=pc686 --prefix=/opt/rtems
creating cache ./config.cache
checking for RTEMS Version... 4.5.0
checking host system type... i686-pc-linux-gnu
checking target system type... i386-pc-rtems
checking build system type... i686-pc-linux-gnu
checking rtems target cpu... i386
checking for a BSD compatible install... /usr/bin/install -c
checking whether build environment is sane... yes
checking whether make sets ${MAKE}... yes
checking for working aclocal... found
checking for working autoconf... found
checking for working automake... found
checking for working autoheader... found
checking for working makeinfo... found
checking whether to enable maintainer-specific portions of Makefiles...
no
checking if the test suites are enabled? ... no
checking if cpu i386 is supported... yes
updating cache ./config.cache
creating ./config.status
creating Makefile
creating tools/Makefile
creating make/Makefile
creating make/custom/Makefile
creating make/Templates/Makefile
creating make/compilers/Makefile
creating doc/Makefile
configuring in tools/build
running /bin/sh ../../../rtems-4.5.0/tools/build/configure
--target=i386-rtems-enable-rtemsbsp=pc686 --prefix=/opt/rtems
--cache-file=../.././config.cache --s
rcdir=../../../rtems-4.5.0/tools/build
loading cache ../.././config.cache
checking for a BSD compatible install... (cached) /usr/bin/install -c
checking whether make sets ${MAKE}... (cached) yes
no
checking for Cygwin environment... no
checking for mingw32 environment... no
checking for executable suffix... no
checking for gcc... gcc
checking whether the C compiler (gcc  ) works... yes
checking whether the C compiler (gcc  ) is a cross-compiler... no
checking whether we are using GNU C... yes
checking whether gcc accepts -g... yes
checking for strerror... yes
checking for strtol... yes
checking for bash... /bin/bash
updating cache ../.././config.cache
creating Makefile
creating install-if-change
creating lock-directory
creating unlock-directory
creating config.h
configuring in tools/update
running /bin/sh ../../../rtems-4.5.0/tools/update/configure
--target=i386-rtems
srcdir=../../../rtems-4.5.0/tools/update
no
checking for bash... (cached) /bin/bash
checking for perl... /usr/bin/perl
creating Makefile
configuring in tools/cpu
running /bin/sh ../../../rtems-4.5.0/tools/cpu/configure
--target=i386-rtems -e
--cache-file=../.././config.cache --src
dir=../../../rtems-4.5.0/tools/cpu
no
creating Makefile
configuring in generic
running /bin/sh ../../../../rtems-4.5.0/tools/cpu/generic/configure
--target=i3
86-rtems -enable-rtemsbsp=pc686 --prefix=/opt/rtems
--cache-file=../../.././conf
ig.cache --srcdir=../../../../rtems-4.5.0/tools/cpu/generic
loading cache ../../.././config.cache
no
creating Makefile
creating size_rtems
configuring in i386-rtems/c
running /bin/sh ../../../rtems-4.5.0/c/configure  --target=i386-rtems
-enable-rt
emsbsp=pc686 --prefix=/opt/rtems --cache-file=./config.cache
--srcdir=../../../r
tems-4.5.0/c
no
checking for make/custom/pc686.cfg... yes
creating Makefile
configuring in make
running /bin/sh ../../../../rtems-4.5.0/c/make/configure
no
checking for i386-rtems-gcc... no
checking for i386-rtems-cc... no
configure: error: no acceptable cc found in $PATH
configure: error: ../../../../rtems-4.5.0/c/make/configure failed for
make
configure: error: ../../../rtems-4.5.0/c/configure failed for c
