Problems with building rtems
Stevens Brian BPSTEVENS at dera.gov.uk
Thu Nov 16 11:50:22 UTC 2000
>From comments sent to me it seems (quite reasonably) that I have not
been clear enough in specifying the problem.
HOST Solaris 2.6
Target Power PC (MVME 2400)
I have built the environment (binutils, gcc, newlib) with the command
bit powerpc and set path to include the install directory.
gcc is the host compiler and powerpc-rtems-gcc is the cross compiler.
I have included the output below. Any help and suggestions would be most
greatfully received.
Thank You
	biff failed:  cannot locate your tty:  ttyname() for file
descriptor 2 returned NULL
	stty: : Inappropriate ioctl for device
/home/brian/bin:/home/brian/util:/home/brian/Office51/bin:/opt/Acrobat3/
bin:/usr/local/bin:/home/rtems/bin:/home/cfgman/bin:/opt/gnu/bin:/opt/GC
C281/bin:/home/rtems/4.5.0/bin:/usr/ucb:/usr/bin:/bin:/usr/cygnus/bin:/u
sr/dt/bin:/usr/openwin/bin:/usr/sbin:/sbin:/usr/ccs/bin:/usr/demo/SOUND/
bin:/usr/cygnus/bin/JBsc/bin:/opt/SES_products/Workbench_33_sun4SunOS5/b
in:/opt/SES_products/Workbench_33_sun4SunOS5/bin/public:/opt/SES_product
s/altia/bin:/opt/SES_products/objectbench30/Objectbench_30_sun4SunOS5/bi
n:/usr/man:/usr/openwin/share/include:/usr/local/mysql/bin:/opt/ptolemy2
/ptII0.4beta/bin:/opt/ptolemy2/ptII0.3/bin:/opt/java2/jdk1.2.2/bin:/opt/
java2/Java-WorkShop3.0/sparc-S2/bin:/opt/frame_shared:/opt/frame_shared/
bin:/opt/SUNWspro/bin:/opt/mathematica/Executables/Solaris:/opt/gimp/bin
:/opt/NSCPcom:/opt/hpnp/bin:/home/rtems/4.5.0/bin
	Removing build directory build-powerpc-rtems ...
	../rtems-4.5.0-beta3a/configure --target=powerpc-rtems
--prefix=/home/rtems/4.5.0 --disable-hwapi --enable-multiprocessing
--enable-cxx --enable-rdbg --disable-tests --enable-networking
--enable-posix --disable-itron --enable-rtemsbsp=powerpc powerpc
	creating cache ./config.cache
	checking for RTEMS Version... 4.5.0-beta3a
	checking host system type... powerpc-unknown-none
	checking target system type... powerpc-unknown-rtems
	checking build system type... powerpc-unknown-none
	checking rtems target cpu... powerpc
	checking for a BSD compatible install...
../rtems-4.5.0-beta3a/install-sh -c
	checking whether build environment is sane... yes
	checking whether make sets ${MAKE}... yes
	checking for working aclocal... missing
	checking for working autoconf... found
	checking for working automake... missing
	checking for working autoheader... found
	checking for working makeinfo... found
	checking whether to enable maintainer-specific portions of
Makefiles... no
	checking if the test suites are enabled? ... no
	checking if cpu powerpc is supported... yes
	updating cache ./config.cache
	creating ./config.status
	creating Makefile
	creating tools/Makefile
	creating make/Makefile
	creating make/custom/Makefile
	creating make/Templates/Makefile
	creating make/compilers/Makefile
	creating doc/Makefile
	configuring in tools/build
	running /bin/sh
../../../rtems-4.5.0-beta3a/tools/build/configure
--target=powerpc-rtems --prefix=/home/rtems/4.5.0 --disable-hwapi
--enable-multiprocessing --enable-cxx --enable-rdbg --disable-tests
--enable-networking --enable-posix --disable-itron
--enable-rtemsbsp=powerpc powerpc --cache-file=../.././config.cache
--srcdir=../../../rtems-4.5.0-beta3a/tools/build
	loading cache ../.././config.cache
../../../rtems-4.5.0-beta3a/tools/build/../../install-sh -c
	checking whether make sets ${MAKE}... (cached) yes
Makefiles... no
	checking for Cygwin environment... no
	checking for mingw32 environment... no
	checking for executable suffix... configure: error: installation
or configuration problem: compiler cannot create executables.
	configure: error:
../../../rtems-4.5.0-beta3a/tools/build/configure failed for tools/build
	Could not successfully configure into build-powerpc-rtems!
Brian Stevens
Tel.  +44 (0)1252 393959
Fax. +44 (0)1252 395120
The Information contained in this E-Mail and any subsequent correspondence
is private and is intended solely for the intended recipient(s).
For those other than the recipient any disclosure, copying, distribution,
or any action taken or omitted to be taken in reliance on such information is
prohibited and may be unlawful.
