RTEMS 4.0.0 bug? LIBC_HEAP_SIZE
Alexander D. Tarkhov
karabass at mitino.ptt.ru
Thu Nov 16 13:48:12 UTC 2000
Hello, rtems users,
I found a strange call to bsp_libc_init() in
bsp_start() function for my bsp.
We use bsp "p4000", target "mips64orion".
So the code is located in
tools/rtems-4.0.0/c/src/lib/libbsp/mips64orion/p4000/startup/bspstart.c
It goes as follows:
BSP_Configuration.work_space_start =
(void *)((unsigned64)((&end) + LIBC_HEAP_SIZE + 0x2000) & ~0x7);
Seems to me that it may cause an error, if LIBC_HEAP_SIZE is the
required size of the heap in bytes. How does the compiler treat such
expressions,
as pointer arythmetics, or as normal integer?
In any case I am going to test the following:
(void *)((unsigned64)(((int)(&end)) + LIBC_HEAP_SIZE + 0x2000) &
~0x7);
Does that seem reasonable?
And what is a strange constant 0x2000?
I understand that few people (if any) are interested in such errors,
and that BSP is my own problem. Still let it just lay in the archives :)
Thank you for your comments.
Best regards,
Alexander Tarkhov
