Compiler needed
Daniel J. Lange lange92 at 2067.resnet.uni.edu
Fri Nov 17 02:11:23 UTC 2000
As I recall, somewhere in the compilation prior to where it needs the
actual target precompiler, it actually builds it from the sources, so as I
recall, if all went fine that far, all you really need to do is set your
path to include it.
DanL
On Fri, 17 Nov 2000, Vasudev Mulchandani wrote:
> Hello !
> I was trying to build rtems for m68k target and configuration
> caved in. It needs the 'm68k-rtems-cc'. Any idea where I can
> get this
> Thanx
> Vasu
