IMFS bug fix
Sturniolo Jose
jsturnio at nec.com.ar
Wed Nov 22 15:23:17 UTC 2000
I'm including a bug fix to the IMFS.
How to replicate the bug:
Perform a put using FTP with a 1 Mbytes file.
Delete (from FTP client) the same file.
The file modified is memfile.c (libc), in function IMFS_memfile_remove()
I added 2 lines checking the pointer. (see comment below)
I tested using the MALLOC test routines in order to check if the memory is
freeded and looks good.
Line 494:
if ( info->triply_indirect ) {
for ( i=0 ; i<IMFS_MEMFILE_BLOCK_SLOTS ; i++ ) {
p = (block_p *) info->triply_indirect[i];
if (!p) /* Check if we have a valid pointer
break;
for ( j=0 ; j<IMFS_MEMFILE_BLOCK_SLOTS ; j++ ) {
if ( p[j] ) {
memfile_free_blocks_in_table( (block_p **)&p[j], to_free);
(block_p **)&info->triply_indirect[i], to_free );
(block_p **)&info->triply_indirect, to_free );
Jose Sturniolo
Product Engineering & Development Department
Development & Implementations Division
NEC Argentina S.A.
