Compiling problems
Mon Nov 27 13:58:18 UTC 2000
Vasudev Mulchandani wrote:
> Hello !
> I was trying to build rtems for pc586 target. I have installed
> the cross compiler successfully. Now I run into the following
> compilation problem.
It looks like your tool version is too old.  pthread.h was moved
from RTEMS to newlib and your tools still expect it to be in
RTEMS.  Grab the RPMS or new patches.
> Making all in src
> make[5]: Entering directory
> `/home/rtems/i386bld/i386-rtems/c/pc586/exec/posix/s
> rc'
> /usr/local/bin/i386-rtems-gcc --pipe -B../../../../../../pc586/lib/
> -specs bsp_s
> pecs -qrtems -g -Wall -ansi -fasm    -mcpu=i586     -c
> -D__RTEMS_INSIDE__ -O4 -o
>  o-optimize/adasupp.o
> ../../../../../../../rtems-4.5.0-beta3a/c/src/exec/posix/s
> rc/adasupp.c
> ../../../../../../../rtems-4.5.0-beta3a/c/src/exec/posix/src/adasupp.c:7:
> pthrea
> d.h: No such file or directory
> make[5]: *** [o-optimize/adasupp.o] Error 1
> make[5]: Leaving directory
> `/home/rtems/i386bld/i386-rtems/c/pc586/exec/posix/sr
> c'
> make[4]: *** [all-recursive] Error 1
> make[4]: Leaving directory
> `/home/rtems/i386bld/i386-rtems/c/pc586/exec/posix'
> make[3]: *** [all-recursive] Error 1
> make[3]: Leaving directory `/home/rtems/i386bld/i386-rtems/c/pc586/exec'
> make[2]: *** [all-recursive] Error 1
> make[2]: Leaving directory `/home/rtems/i386bld/i386-rtems/c/pc586'
> make[1]: *** [all-recursive] Error 1
> make[1]: Leaving directory `/home/rtems/i386bld/i386-rtems/c'
> make: *** [all-recursive] Error 1
> Any help is greatly appreciated ..
> TIA
> Adios
> vasu
