Patch to 'getcwd()'.
Sergei Organov
osv at javad.ru
Mon Nov 27 17:33:57 UTC 2000
Hello,
Below is a patch to 'getcwd()'. It ensures _closedir(dir) is called even on
error exit from the routine.
BR,
Sergei Organov.
Index: getcwd.c
RCS file: /var/local/cvsroot/oar/rtems/c/src/lib/libc/getcwd.c,v
retrieving revision 1.1.1.1
retrieving revision 1.2
diff -u -b -r1.1.1.1 -r1.2
--- getcwd.c 2000/11/17 13:05:39 1.1.1.1
+++ getcwd.c 2000/11/27 17:23:54 1.2
@@ -74,7 +74,7 @@
size_t size;
register struct dirent *dp;
- register DIR *dir;
+ register DIR *dir = 0;
register dev_t dev;
register ino_t ino;
register int first;
@@ -254,6 +254,7 @@
bpt -= strlen (dp->d_name);
bcopy (dp->d_name, bpt, strlen (dp->d_name));
(void) _closedir (dir);
+ dir = 0;
/* Truncate any file name. */
*bup = '\0';
@@ -271,6 +272,8 @@
/* FALLTHROUGH */
err:
+ if(dir)
+ (void) _closedir (dir);
if (ptsize)
free (pt);
free (up);
