loopback interface
Eric Norum
eric.norum at usask.ca
Thu Nov 30 14:41:22 UTC 2000
"Smith, Gene" wrote:
> Joel,
> Do you know if the loopback/localhost interface is functional in the rtems
> tcp/ip stack?
I believe it is.
> I tried to enable it in networkconfig.h by defining RTEMS_USE_LOOPBACK and
> get a warning when I compile that the type of the pointer
> rtems_bsdnet_loopattach (a function pointer) is the wrong type. It does
> appear that the lo attach function, rtems_bsdnet_loopattach() has a
> different return type and parameters than my eth interface attach function
> uti596_attach().
Yes, that's an annoying warning. I've never bothered to go in and fix
it though. Someday, perhaps......
> Then when I try to run the code, I get a rtems_glue.c error "Can't set lo0
> broadcast address - Invalid parameter".
Actually that's just a warning, not an error. In any case, the message
disappeared many snapshots ago.
> The primary interface (eth) seems to be running ok as before. I have not yet
> tried to use the lo interface.
As far as I know the loopback interface works properly. EPICS needs it
and seems to be running just fine.
Eric Norum eric.norum at usask.ca
Department of Electrical Engineering Phone: (306) 966-5394
University of Saskatchewan FAX: (306) 966-5407
Saskatoon, Canada.
