debug variant & 302 timers
    Ralf Corsepius
    corsepiu at faw.uni-ulm.de
    Wed Nov  1 23:27:16 UTC 2000
Antti P Miettinen wrote:
> Once upon a time Joel wrote
> > OK.  Running at a -O1 is not great but running the debug variant is
> > a killer!!!  On each malloc/free, the heap is walked.
> Hmm.. should building with `make VARIANT=DEBUG' cause RTEMS_DEBUG to
> get defined?
No.
> It does not for me. Is this dependent on some config time
> option?
Yes, in newer snapshots it's --enable-rtems-debug.
In older versions you had to define it inside the target-opts
section in your BSP's <BSP>.cfg.
Ralf
Ralf Corsepius
Forschungsinstitut fuer Anwendungsorientierte Wissensverarbeitung
(FAW)
Helmholtzstr. 16, 89081 Ulm, Germany     Tel: +49/731/501-8690
mailto:corsepiu at faw.uni-ulm.de           FAX: +49/731/501-999
http://www.faw.uni-ulm.de
