minimum stack size was Re: #define delay(...)
Gerke Kok gerke.kok at tpa-nl.com
Mon Nov 13 07:48:40 UTC 2000
Should not the stacksize be given at the start of the task in the
create_task call? This is used in many systems and is very flexible.
(Althoug I do know it taks more admin. for the kernel)
wkr,
Gerke
-----Oorspronkelijk bericht-----
Van: Joel Sherrill [mailto:joel.sherrill at OARcorp.com]
Verzonden: Friday, November 10, 2000 18:59
Aan: Sergei Organov
CC: rtems-users at OARcorp.com
Onderwerp: minimum stack size was Re: #define delay(...)
Sergei Organov wrote:
> > This name is a relic from the very EARLIEST days of RTEMS.
> "EARLIEST days of RTEMS" recalled me that I've had another suggestion for
> RTEMS. What if in addition to one lower stack size limit
> RTEMS_MINIMUM_STACK_SIZE we introduce another constant,
> let's say, RTEMS_ABSOLUTE_MINIMUM_STACK_SIZE that will be indeed close to
> absolute minimum for given architecture. All the test programs (as well as
> applications) then will continue to use the former constant, but RTEMS
core
> will check input stack size by comparing it to the latter constant.
> The problem with current approach is that the constant is actually too
large
> (e.g., 8K on PowerPC) and as RTEMS core doesn't allow to create tasks with
> smaller stacks, light-weight tasks take too much memory for stack. Using
my
> suggestion ABSOLUTE_MINIMUM will be somewhere around 1K for PowerPC thus
> saving 7K for every light-weight task. Or did situation change in this
area
> since RTEMS-3.6?
Hasn't changed but it has irritated me and I have something in mind.
What about minimum stack size defaulting to the current
value and the user being able to specify their own default size as an
override.  What do you think of this?
I have also toyed with the idea of moving the fields in CPU table
that are shared by all ports to the regular configuration table.
> BR,
> Sergei Organov.
