Best PC-based OS for RTEMS / GNAT development?
mcollins at hawkeye.sps.mot.com
Tue Nov 14 18:25:24 UTC 2000
On Tue, Nov 14, 2000 at 09:36:59AM -0800, Mike Silva wrote:
> Anybody have an opinion on the best OS to run (on a PC) for RTEMS / GNAT
> development? At this point I know nothing outside the Windows world
> (however, I've grown to despise Windows...) Thanks.
Jake Janovetz wrote:
> I would certainly say Linux (for RTEMS development and for anything else).
> Which variant you use is up to you, but OAR seems to be fairly RedHat
> friendly.
I use Debian's distributions and have not had any problems of note.
Although I generally build from source, Joel creates .deb packages
which I've tested and they work just fine.
I've also done some SPARC/Solaris RTEMS development, and the only
problem encountered is a well-documented problem with wildcard expansion
which has a known work-around (the problem may not even exist in 4.5;
I haven't built under Solaris in a long time). Solaris is available
for x86, and I would expect the environment to be quite similar to
that for SPARC.
Probably any UNIX variant is a better choice than that other operating
system.
-- MC --
